tantares
Jul 21, 2020Follower
How to use WN1000RP to extent Direct WiFi range of a camera
Hi,
I'm trying to extend the P2P WLAN range of my camera, which is terrible weak. It's a Yukon nightvision device, which can be remotly controlled from a smartphone using StreamLine software.
Also I can successfuly initialize the repeater, I'm unable to access the camera via this Netgear device. On hte other hand I can use the booster to extend the range of my Internet/WLAN router without problems.
Is there a technical reason, which makes the booster unsuitable for direct Wifi connections?
Any hint is appreciated
Tony
No RepliesBe the first to reply
