Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
If the network name changes will the extender pick it up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-05-10
11:32 AM
2021-05-10
11:32 AM
If I change the name of the wifi network do I have to instruct the extender or does it adjust automatically..?..
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-05-10
06:30 PM
2021-05-10
06:30 PM
Re: If the network name changes will the extender pick it up?
If you change the routers ssid/password, you'll need to reinstall the extender.
Its pretty easy to do.
go to netgear.com/support/
type in your actual modem number and it'll take you to install guides.
Simply factory reset the extender (push and hold reset for 7-15 seconds while powered on)
then you can start from factory and reinstall. pretty easy
Message 2 of 2
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
