rebretz000's avatar
rebretz000
Follower
Dec 26, 2017
NETGEAR Nighthawk AC1900 Desktop WiFi Range Extender no internet
Ever since the latest firmware update my extender will not put out a consistent wifi signal and devices will not connect when there is a signal. When will a fix come? I have 2 netgear routers and two extenders and all are having issues ever since the latest update.
I have factory reset all 4 of my netgear deives but nothing works.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to roll back to the old firmware and see if that fixes the issue or if the same problems are happening?
    DarrenM
