Orbi WiFi 7 RBE973
Reply
Netgear AC1200 EX6120 can it pull via Wifi while pushing over Ethernet
Zach1
I have the Netgear AC1200 EX6120. I also have a safe I would like to set up a server inside of. However I do not want to run Ethernet across the floor in my house to access it. The safe does have an outlet next to it for power. Can I connect the Range extender to wifi and then run Ethernet to server to connect to it via wifi?
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 4
Guru
Re: Netgear AC1200 EX6120 can it pull via Wifi while pushing over Ethernet
You're putting a server inside of a safe? I hope you have it vented 🙂
to simplify, are you asking if you can hardwire the server to the extender? (running a wire through the safe I take it)? If so, yes, you can connect devices to extenders ethernet ports
Message 2 of 4
Zach1
Is there something i need to do to turn on that port? I tried hooking it to a laptop after it was connected to the Wifi and it was not connecting to the internet
Message 3 of 4
Guru
 did you setup the extender via wps or using the installation assistant?
I'd recommen doing it via the installation assistant.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 560 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
