Orbi WiFi 7 RBE973
Reply
Netgear AC1200 WiFi range extender EXS6190
johnkf
Having problems with my unit getting the following Message "LAN Disconected then - 5-30 Seconds LAN connected this stops any program that was been streamed then have to re start unit has worked ok for last 6 months
Help Pls
Thanks
John
Message 1 of 3
Guru
Re: Netgear AC1200 WiFi range extender EXS6190
You have the EXS6190
What fimrware is on it?
What router is connected to it?
Do you have the extender hardwired in or what device is giving you the lan notice?
Do all devices have this issue or just one?
Message 2 of 3
nikim72
@johnkf wrote:
Having problems with my unit getting the following Message "LAN Disconected then - 5-30 Seconds LAN connected this stops any program that was been streamed then have to re start unit has worked ok for last 6 months usps tracking
Help Pls
Thanks
John
Hey john,
If you config system manually , let it to reset.. May your lan assign similar ip to other devices.. Not sure this could be the problem , but can be one of case... Reset and do again..
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1019 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
