Ralph1950
Dec 18, 2024Follower
Netgear AX 1600 Wifi Router
I have recently purchased a HP All in One OfficeJetPro 9120e.
The printer says I need to press the 'WPS' button on the Router to connect. I cannot find a 'WPS' Button on the router. How to I get them to see each other?
1 Reply
What router do you have? AX1600 is a speed.
If its the RAX5, the manual (page 78) goes over using the wps wizard on it.
4-Stream AX1600 WiFi 6 Router Model RAX5 User Manual
