Orbi WiFi 7 RBE973
Reply
Netgear EX6100, 10.0.0.250 IP Address after a reset
rbscycle
Initially worked fine.  Decided to set it up as an Access Point.  Setup failed.  Did a reset and tried the setup again, it failed again.  Tried to reinstate as the original Extender.  After some poking around, found it had a 10.0.0.250 IP.  I could connect to the Netgear home page with it.  Tried to fill out the "Create New Account", the page resets and back to the beginning.
Model: EX6100|AC750 WiFi Range Extender
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Netgear EX6100, 10.0.0.250 IP Address after a reset
Hello rbscycle
Make sure you do not have a pop up blocker or ant virus causing the issues when setting up the extender.
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello rbscycle
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5775 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
