Sayket's avatar
Sayket
Netgear wifi not showing for range extender in tp link router.
1 Reply
  • plemans's avatar
    You gave us nothing to go off.
    what extender do you have?
    what firmware is on it?
    What actual router are you connecting it to?
    What is actually going on?
    Did you set up the extender?
    What process of setup did you use? WPS? Installation assistant? The app?
    Details are key to helping.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
    You could also contact support if the extender is new.
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
