Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk EX8000 not using 5 GHz WiFi backhaul not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-02
05:47 PM
2021-01-02
05:47 PM
I can find no information on Maximum Throughput using the 5 GHz band for backhaul. What is it? Do I set it up or is it automatic? The 2nd LED is unlit indicating that the extender is using the 2.4 GHz band, correct? How do I change this? Thanks...
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-01-03
07:38 AM
2021-01-03
07:38 AM
Re: Nighthawk EX8000 not using 5 GHz WiFi backhaul not working
have you logged into the extender and looked at the status page?
It shows backhaul connection speeds/links.
You can take a screen snip and post that here.
What router are you connecting it to?
How far from the router is the extender?
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-10
02:32 AM
2021-02-10
02:32 AM
Hi. I have this problem too. I have been using the extender since April last year. It’s brilliant! A few days ago I lost the 5G backhaul. I have done a complete factory reset and tried a WPS set up. Regardless it is not setting up 5G backhaul. The router is an Asus RT AC 66U. Any advice most welcomed! Thanks in advance
Message 3 of 3
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
