Orbi WiFi 7 RBE973
Reply
Nighthawk X4 |AC2200 WiFi Range Extender open networks...
newbiedad
Follower
Good morning all,
     I have tried searching through the forum, and have found nothing related. I purchased and setup the AC2200 last night. Install seemed to go smoothly using the wps function. Signal strength seems good, and my devices all see the (2) new networks created. Problem is, that the (2) networks created are not named as they should be (per instructions), and they are open (unsecured)... I cannot figure out how to secure them, and when I used the www.mywifiext.net to look at the device, it offered a firmware update (which of course i did), and now it does not seem that I can connect to it via my iphone. I have spent a couple of hours messing with this thing, and becoming increasingly disapointed (and frustrated). If anyone can help, thanks in advance.
Model: EX7300|AC2200 WiFi Range Extender
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Nighthawk X4 |AC2200 WiFi Range Extender open networks...
Hello newbiedad,
If you recently purchased the device we recommend contacting support.
https://www.netgear.com/support/default.aspx
~Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 652 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
