- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4 WiFi Range Extender using same SSID?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there. I am using using netgear router at home,the nighthawk R8000. I've just purchased the AC2200 extender to increase coverage at home. However I don't want the extender to have EXT at the end because i would have to keep swithing wifis. I have tried manually to name it exactly to same the current SSID from the main router. Is this the right way and is it good? It works sometimes but sometimes it fails to get IP and wifi drops and the light is red on the extender. Any advice would be appreciated.
Thanks
Swadeep
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello swadeepc
You want it to have a separate SSID because it is not designed to auto switch networks when moving around your home.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello swadeepc
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4 WiFi Range Extender using same SSID?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
