Orbi WiFi 7 RBE973
Reply
Pc can't connect to extender ex3110
MaxVor
Hi,
I recently bought the ex3110 extender for my appartment, and I am having a lot of trouble with it.
It worked alright for a while, but now it won't connect to my laptop anymore (asus). It works fine on mobile phones most of the time, and it works on a macbook air and ipad, but i cant for my life get it to connect to my laptop anymore.
I've tried a heap of different things, like using a manual DNS adress, manual IP adress, all the common ipconfig and netsh commands, i've tried deactivating other network card that might cause conflict, i've reset my network card, i've restarted the main router, i've restarted the extender.
I don't know what to do anymore.
I hope you can help me out.
Best regards
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 6
Guru
Re: Pc can't connect to extender ex3110
What router is it connect to?
Are you installing it using WPS or using the installation assistant?
Message 2 of 6
MaxVor
Hi, thanks for your reply.
it's connected to a freebox, model F-GW06250C.
i installed the extender with the installation assistant.
best regards
Message 3 of 6
Guru
I couldn't find much info on that specific router. Looks like maybe a single band router?
have you tried setting it up using fastlane mode with the 2.4ghz as the backhaul?
Message 4 of 6
MaxVor
I honestly don't know if it's single band or not, I am not Very versed in that kind of stuff .
how do I set it into fast lane mode as you said?
thanks a lot for your time.
best regards
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1164 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
