Sebast29's avatar
Sebast29
Routeur Wifi
bonjour à tous,
je cherche un routeur Wifi récent avec lequel je pourrais :
- programmer des plages horaires d'émission / silence Wifi
- faire du filtrage Mac
- pouvoir régler la puissance d'émission
merci de m'orienter !  ;-)
  • StephenB's avatar
    All the current Netgear routers let you set up a schedule and all support MAC address filtering.
    You can see some models that support transmit power settings if you expand the models here: https://kb.netgear.com/30111/How-to-adjust-the-Wi-Fi-transmit-power-of-your-Nighthawk-router This is an older KB article, there likely are newer Nighthawk routers that also have this feature.  You can check the user manuals for specific models prior to purchase.
    • Sebast29's avatar
      Sebast29
      bonjour,
      thanks for your answer
      so, you confirm i can change power level on a Nightawk R7000 ?
      thanks
      • StephenB's avatar
        The R7000 and the R7000p are both listed in the KB article I posted above - so I think the answer is yes.  Note I don't work for Netgear.
