Orbi WiFi 7 RBE973
Reply
Set up 2700 Extender, asked for login details?
Rayfriend
Follower
Just bought the 2700 so I can get internet right at the back of the house, set it up with no problems and it worked for about an hour.
All of a sudden, this pop up box appears saying 'To view this page, you must log in to this area on www.mywifiext.net:80: - it then asks me to put in my 'Name' and 'Password'
Very confused, any help or advice is gratefully received!
Rachel
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Set up 2700 Extender, asked for login details?
Hello Rayfriend
If you never set up a username and password when setting up the 2700 i would try the default Username of Admin and the password is password. also make sure the firmware is up to date on the 2700. hope to hear your feedback
DarrenM
Message 2 of 3
nhann
NETGEAR Employee Retired
Hi Rayfriend,
To add to what DarrenM said, if you aren't able to access the web interface, you can download the latest firmware and manually install it to your extender. http://support.netgear.com/product/EX2700
If www.mywifiext.net does not work, you can also try mywifiext.net (without www.) or 192.168.1.250
NhanN
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4986 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
