Orbi WiFi 7 RBE973
Reply
The extender is not showing up on my network
Buzz9078
Follower
Good Evening,
My extender is showing that is working but is not showing on the list of available networks on my TV.  How do I solve this
Model: EX6250|AC1750-WIFI MESH EXTENDER
Message 1 of 2
Guru
Re: The extender is not showing up on my network
You have the EX6250?
What firmware is on it?
What router is it connected to?
Did you set it up using wps or the installation assistant?
Did you set it up in mesh mode (onessid)?
If you set it up using wps or using mesh, it uses the same ssid as the router and devices automatically roam between it and the router's ssid as needed. So you won't "see" it as a seperate network.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 631 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
