wheatleigh's avatar
wheatleigh
Follower
Feb 22, 2013
Trouble logging into admin for WN802t v2
When trying to reach the administration console at routerlogin.net and even directly using the IP address for the access point, it will allow me a login but only to my VPN firewall. The model for the firewall is the FVS318v3.
Can anyone let me know what may be happening?
1 Reply
  • reset the AP unit.
    Most all AP will have default IP.. refer to manual at support.netgear.com and download.
    you may need to setup static IP on PC and connect to WNxx and see
