- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Uanable to Join network "NETGEAR_EXT" Network - Exrender not found
- Mark as New
- Bookmark
- Subscribe
- Permalink
MAC OS SEQUOIA V15.11
Installed Network hardware - Netgear Orbi RBK852 Tri Mesh Router & Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Uanable to Join network "NETGEAR_EXT" Network - Exrender not found
Wow, your description left a lot to be desired.
You posted about a _ext network but that you have an RBK852 which isn't an extender.
Maybe a better description of what you have for your setup, what you're trying to do, and where it fails would help us to help you better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem resolved - re booted Router & Wifi Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
might mark it solved then so others aren't still trying to fix it
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is good you are troubleshooting the issue! Once resolved connecting to the "NETGEAR_EXT" network should be seamless and smooth.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
