Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using two extenders
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-13
06:02 PM
2018-12-13
06:02 PM
Using two extenders
I want to connect an N300 and already am using an AC1200.
They will connect to a Windstream T3200 wireless router.
How do I and the N300 extender?
Thank you
Thank you
Model: EX2700|N300 WiFi Range Extender
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-14
10:38 AM
2018-12-14
10:38 AM
Re: Using two extenders
You can just set it up in the normal way, though I suggest not pressing on WPS.
If the router network names and the AC1200 extender's network names are the same, then you could end up daisy-chaining through the AC1200 extender. That would reduce your throughput to the EX2700. The workaround is to change the 2.4G SSID in the AC1200 to a new name.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-14
12:33 PM
2018-12-14
12:33 PM
Can you help me change the SSID?
Thank you for your time.
Message 3 of 3
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
