granthar's avatar
granthar
WG302 setup
I have a Netgear WG302 which I have setup as a repeater connecting to a Draytek 2820n via wi-fi. It is being used to connect a piece of kit that only has an ethernet port without having to run an ethernet cable back to the router.
I can connect to the Netgear and can see the local network but cannot get to the internet. What am I missing on the settings?
  • The client device is a Squeezebox Touch, I am not sure there is the facility to add in DNS servers
  • I'm not familiar with the device so I would look the settings or manual
    have you tested with computer behind the wgxx and see?
