DADEO's avatar
DADEO
Novice
Oct 26, 2012
WNCE2001 Question?
Can I use the WNCE2001 on a A/V Receiver that has a Ethernet port to connect but no wireless specific port? It seems I can, but info always shows TVS, Blue ray players, Game consoles, not A/V Receivers. Thank you.
  • I could have said that better. What I meant was where you can plug in the wireless adapter. Some A/V receivers have this and some have the ethernet plug to hard wire to your router. Can I plug the WNCE2001 in the ethernet plug and go wireless?
