altas's avatar
altas
WNCE2001 no PING and access to netshare
Hello
i have new a WNCE2001 with the latest firmware .26.
i have configured sucessfully the connection to my WLAN at home...
after that i have connected the WNCE2001 ouver a LAN Cable with my Netbook to do some tests.... but then i noticed that i can not ping any other LAn Device in my network behind the WNCE2001 and also no connection to my NAS Shares...
the only thing what i have is Internet connection....
so then i have tried to connect the WNCE2001 webinterface from a different computer where is connected with wired cable... not possible also ping not possible...
is that normaly for the WNCE2001 that every Device behind have no access to the internal LAN shared and Devices??
altas
  • i have now noticed that the WNCE2001 is possible to ping after 20sec from power off.... then packes loos 100%....
    i think i send it back to factory... this device goes wrong
  • seems to be a problem with my DSL WLAN Router....
    i have not setup a 2nd one and with this WLAN i have no problem...
  • for some reason i have to add the Device WNCE2001 on my Centro Grande ADB/Pirelli Router then reboot the Router and everything is working as it should :D:confused::p:):):cool::cool:
