richard0
Jan 06, 2012Aspirant
Wap cg3100 & wndap360
I have Telstra CG3100 cable modem just installed. i want to extend wireless range. can i use a power injector together with WNDAP360? is this suitable?
what do i do to set up with the modem - bridge?
Richard
Richard
- jmizoguchiVirtuosoCG3100 is cable modem/wireless router so if you have ethernet able to remote location then you can use PoE injector and power any PoE capable AP devices
- richard0Aspirantgiven that CG3100 is dual band what is best AP any one can recommend?
- jmizoguchiVirtuoso360 is Dual band with PoE
