- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Extender or Repeater
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Extender or Repeater
125ft is a stretch for distance. Potentially you can get it working but its expensive to buy something that "might" work.
Potentially you could use a powerline device if the pole is on the same power circuit as the home.
You might have to try several things to get it working properly.
Got an old router sitting around? Some have a repeater/extender mode or can have 3rd party firmare installed that could support those modes.
Otherwise, it might be worth buying one from a place with a generous return policy incase it didn't work to your satisfaction.
Or you can bite the bullet and bury an underground rated ethernet cord.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A light pole? You mean, as in outside your house?
125 ft might be a bit much for WiFi, especially if there is anything that can block the signal such as foliage.
Bear in mind, that a repeater doubles the WiFi traffic. Depending on your ISP speed and bandwith usage, that could be a problem. An "extender" generally refers to an access point that is connected via ethernet. If at all possible, go that route and bury an ethernet cable as it will be a heck of a lot more reliable and cause less traffic on your WiFi.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
