psl19's avatar
psl19
Tutor
Jan 02, 2019
Wifi range extender
I installed a Ring Doorbell and the app says my wifi is weak.  Can you recommend a plug in wifi extender?  I have a Netgear Nighthawk AC1900 model D7000v2
Thanks
  • You are looking for 2 mbps speed to/from the doorbell.  So perhaps try measuring the speed using a mobile phone (speedtest.net). Try both 2.4 ghz and 5 ghz.
    If the Ring doorbell is the only device you'll be connecting to the extender, than the EX3700 would be a cost-effective option.  You'd need to put it somewhere in between the doorbell and the router (so it will get a solid signal from both).
1 Reply
  • StephenB's avatar
