mariposavv
Jul 07, 2012Follower
Wireless N300 and HP Photosmart Printer
My router cannot detect my printer when I turn access control list on after adding the printer as a device in the list. It only works when I have access control turned off. Anyone else having same issue?
1 Reply
- jmizoguchiVirtuosonot all device can use control list.
looks like do not use control list. if you have WPA2 then you should be fine with your network.
