- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wx6120 extender, says incorrect password
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve done the reset and that didn’t work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wx6120 extender, says incorrect password
You have the EX6120?
What firmware is on it?
What router is it connected to?
Did you set it up using wps or using the installation assistant?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connected to a Vodafone router using wps as just got an error message when on computer
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware is the software (firmware) running the device.
Vodafones wps function doesn't always work as it should.
Try factory resetting the extender (push and hold reset for 7-15 seconds while extender is powered on), then reinstall it using the installation asssistant and NOT WPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you were resetting, did you push and hold reset for 7-15 seconds while it was powered on?
WPS can get coded different and even though the colors show proper, it not work right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried hardwiring into a pc/laptop (disable the pc/laptops wifi) and setting it up that route?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
