kss9
May 31, 2021Follower
additional wifi router to use with EX8000
Hello, I currently have a netgear AC3000 Desktop Extender(EX8000) and would like to add another wifi extender. Would someone have a recommendation for a less expensive product that will work well for this issue?
The ex8000 extends the signal towards a large area in the back half of the house. Now, I would like to extend the signal upstairs, to a smaller area, not far from the router. Due to the floor/walls layout though, the current router signal carries the signal well only to one half of this area.
Thank you for your help!
1 Reply
Netgear has a ton of extenders.
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
I will say I'm a fan of the triband extenders because of their dedicated backhaul.
But basically you can search the ones that meet the requirements that you want.
