- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
eax80 as extender does not show up routerlogin.net.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im getting a email saying there is a update for my eax80. But i only see my ax12 on routerlogin.net. Did I set up the ax8 correctly as a extender? If I cant see it how do i update it?
As a follow up I found the eax 80. But I hit update and it says there is no update? I think I have it set up to auto update. Why did i get a email then?
I went to mywifi.net and it says"You are not connected to your extender's WiFi network." It tells me to go to http://mywifiext and I can finally see the extender. So im really confused now. Is it or not hooked up to me ax12 as a extender?
What is a mesh and is that better way to make all this work? How do i do the install for a mesh if its better?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: eax80 as extender does not show up routerlogin.net.
I usually just use the IP address to access the extenders.
what version of firmware are you on?
the latest on the support site is 1.0.1.64
https://www.netgear.com/support/product/eax80.aspx
sometimes those emails get sent out late
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
