Orbi WiFi 7 RBE973
Reply
ex2700
ajmjr
Follower
ex2700
I just changed internet service provider and cant get the wifi extender to work with the new provider. no problems with previous provider. tryed to connect with WPS but router light on extender just flashes
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: ex2700
Firmware on your extender?
Router you're trying to connect to?
have you factory reset the extender? Push and hold reset while the device is powered on? the lights should change/blink when held long enough.
have you tried setting up via the netgear smart connect wizard and not via WPS? maybe whoever makes the router didn't implement wps correctly. The support site has install guides showing this as well as videos with the smart connect walk though.
https://www.netgear.com/support/product/EX2700.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 477 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
