Orbi WiFi 7 RBE973
Reply
very low download/upload speed with wn3000rp extender
chanDr
Hi,
I've just bought an WN300RP WIFI  extender, all installation seems to be ok, but I see that download and upload speed are extremly low with that component.
in test and optimal conditions (router, wifi extender and computer are in the same room , close to one another (les than 50 cm)),connecting directly to wifi router I have 30-40 Mb/s in download but only 0.5.Mb  (max  1Mb) if I Pass through wn3000 extender.This is 50 times lower !
I Disconnect ipv6 on my router and in my computer, reset the wifi extender, reinstall the all,  but I have always the same result.
Is  this normal?
thanks for your  responses.
Message 1 of 5
Accepted Solutions
chanDr
Re: very low download/upload speed with wn3000rp extender
hi,
i think I have an explanation, this is an encrypytion issue:
when I m in 'no security' or in 'WPA/WPA2 mixed' speed is good but when I'm in WPA2-AES speed is very low.
strange because firmware is up to date.
can someone confirm this non compatibility ?
Message 5 of 5
All Replies
Retired_Member
Not applicable
Placing the extender 18 inches from the router could be a problem. What does the installation manual state regarding placement?
Message 2 of 5
chanDr
hi,
thanks for your quick response
when the extender is at 3 meters from router this the same. by the way figures I gave you where for upload not download...
Message 3 of 5
chanDr
and there is nothing in the install doc regarding the minimal distance, but I suppose that 3 meters is a good distance
Message 4 of 5
chanDr
hi,
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 7460 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
