Orbi WiFi 7 RBE973
Reply
wn2500 extender wont sync to d2200d dsl router
techsupportsuck
my new n600 wn2500 extender wont sync up with d2200d dsl router
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: wn2500 extender wont sync to d2200d dsl router
Hello Techsupportsuck
Have you tried to connect the extender with both methods with WPS or by going through the wifi setup? Try to factory reset the extender. Also make sure your main router is set to WPA2 security and also try to change the wireless channel.
DarrenM
Message 2 of 3
All Replies
DarrenM
DarrenM
Message 2 of 3
techsupportsuck
Darren, changing wireless settings on router to wpa2 worked. Much appriciated. Can't believe tech support person did not know this, even after they went to my wireless settings and I asked them to make sure its set correctly. Maybe this can get to them. Anyway thanks again.  Jeff
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3285 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
