× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Best Modem for Nighthawk XR500 Router ?
manxdune
Follower
Best Modem for Nighthawk XR500 Pro Gaming Router ?
Prefer Netgear so they communicate.
What combination are people running that’s working well ?
Need to use it for PlayStation 4
Thanks
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 5
Netduma-Fraser
NetDuma Partner
Re: Best Modem for Nighthawk XR500 Router ?
Hi manxdude, there is no particular recommended modem as far as I am aware. As long as it can pass traffic through to the router there shouldn't be any problems.
Message 2 of 5
Netduma-Fraser
NetDuma Partner
No. The quality of settings you get in a combo are not very exhaustive and their QoS is not very good at all. Your ping does not increase by any conceivable amount by introducing a router <1ms usually.
Message 3 of 5
Netduma-Fraser
NetDuma Partner
No you wouldn't gain an advantage because the optimal setup would be to put the combo in modem mode as you want the XR500 to control everything.
Message 4 of 5
Netduma-Fraser
NetDuma Partner
I wouldn't have thought it'd make any significant difference whatsoever. The only upside to that scenario is you have 1 device for internet rather than 2.
Message 5 of 5
Discussion stats
  • 4 replies
  • 12427 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
