× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Double Nat issue for Xbox One
jamses100
I keep getting a NAT type moderate and UPnp not successful or double NAT on my xbox network settings, I set everything up correctly. I tried unplugging the ethernet cable that connects my xbox to the xr500 and connecting but it still says the same thing. Even when its directly plugged into my xbox it says this, am I doing something wrong? Help me please!
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 8
Guru
Re: Double Nat issue for Xbox One
What modem is the XR500 connected to? A lot of times, we find that someone is using a combo device and then a router. This causes double nat situations. here's netgears info on what double nat is.
https://kb.netgear.com/30186/What-is-Double-NAT
and how to fix it.
Message 2 of 8
jamses100
yes thats what it was, I called my internet provider and they bridged it but now what happens is that the NAT will be open for a brief time and then turn back to Double NAT
Message 3 of 8
jamses100
I always have to connect back to the XR500s wfi on my xbox for it to say open NAT, its really annoying.
Message 4 of 8
jamses100
the modem was ATT
Message 5 of 8
Guru
Which one and house do you know they set it properly?
Message 6 of 8
jamses100
It was a ATT modem/router, they turned it into just a modem and then bridged the ATT modem to the XR500. What do you think they did wrong so I can call again.
Message 7 of 8
Guru
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Be sure to set a IP address reservation for the xbox ON the XR router.
Press the power button and hold it until the xbox shuts off. Reboot the modem and router. After the modem and router are back to ready. Power ON the xbox. Should have OPEN NAT.
Message 8 of 8
Discussion stats
  • 7 replies
  • 3033 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
