Reply
Clean install
Compoza_
Luminary
Clean install
I have seen somewhere here in the forum but cant find it, but there is a way you could clean install the router, through a computer directly to the router, right?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Clean install
What you're looking for is TFTP I believe which allows you to install the firmware while bypassing the boot process and any issues that may be there, then a factory reset after its upgraded https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP?artic...
Message 2 of 2
All Replies
Netduma-Fraser
NetDuma Partner
Re: Clean install
Message 2 of 2
Discussion stats
  • 1 reply
  • 526 views
  • 0 kudos
  • 2 in conversation
Announcements
