- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection benchmark test not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
It used to work then started stalling at upload ping under load and now will not start at all. I have done a factory reset a few times and tried reinstalling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection benchmark test not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
No error messages just this....I have an R2 also that works on this setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I hope this works. It times out after about 5 mins but I can access the rest of the routers menu as normal as it doesn't lock me out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
that never worked then....d'oh
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That might have worked
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Setup is adsl modem with XR500 in dmz . The XR500 has nothing attached to it so isn't causing me a problem right now and I have the R2 running the network as you sent me a later build for it , I have a different name on the Netduma forum. No settings have been changed on the XR500 , connection benchmark just didn't work properly then ceased to work at all. I did have the XR500 on my fibre connection and connection benchmark sort of work but was not able to be altered..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
They're on separate broadband connections, XR is on adsl 13 down 1 up and R2 on fibre 550 down and 35 up. Because you mentioned it I just set up fibre-R2-XR500 and connection benchmark worked though still not affected by reducing qos. I have returned XR500 to adsl and the first test got as far as the upload speedtest then stopped and won't work now. I have rebooted Plusnet router and changed cable even though I had connection and it won't run. The plusnet router is basic so the only setting changed is the dmz. At least I know now it's not your firmware and apologise for bothering you.
p.s. the R2 is running brilliantly on the last firmware you sent me.
Thank again for your help Fraser. When I get some time I'll see if I can put a different router in front of the XR500, I tampered with openWRT so have a spare.
