Reply
Current best DumaOS version?
Rainyi
Tutor
I currently want to know what the best firmware to use on the XR500 that doesn't get errors and is of course stable? I've heard that possibly that V2.3.2.114-DumaOS3.0.203 is stable but correct me if I'm wrong? Meanwhile to while im asking this question is there a time date for the next beta firmware release for the XR500?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 8
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Current best DumaOS version?
In my opinion based on bug reports we've seen, that version is the most stable - it is important to mention that it is still a beta build and so there may still be some bugs.
Message 3 of 8
All Replies
Guru
Best bet is to read through the beta forum post on the new firmware. users post with issues and the Netduma staff regularly post on there.
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-108-XR500/td-p/...
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 8
Netduma-Fraser
NetDuma Partner
Message 3 of 8
Rainyi
Tutor
Thanks, for the reply. Smiley Happy
Message 4 of 8
generozen
Hi
I am current running firmware Dumas OS v2.3.2.63-dumasos3.0.92 on my XR500 and it has been pretty stable.
What are the best steps for me to update to latest dumas os3.0 version without having issues?
Message 5 of 8
Netduma-Fraser
NetDuma Partner
That's quite an old version, the latest is this: https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0
If you choose to upgrade then do a factory reset once it is done
Message 6 of 8
generozen
Thanks for the quick reply.  Is this the most stable 3.0 version available now?
What are some things that still dont work on it.?
Message 7 of 8
Netduma-Fraser
NetDuma Partner
In my opinion yes, nothing too serious that I am aware of
Message 8 of 8
Discussion stats
  • 7 replies
  • 1846 views
  • 3 kudos
  • 4 in conversation
Announcements
