- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Downgrading to older firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Been looking through the boards for step by step instructions to downgrade from the Open beta to the last stable firmware as the QoS issues are really starting to cause me issues.
If anyone can point me in the right direction that would be great.
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
You can download the latest stable firmware here (Firmware Version 2.3.2.56) :
https://www.netgear.com/support/product/XR500.aspx#download
Then in the left panel on the web administation:
Setting -> Administration -> firmware update
Click browse and the upload the downloded firmware et choose yes when the popup advertissement (downgrading) appear.
It's better to reset all the configuration after the flash :
Setting -> Administration -> backup settings : Erase
Best regard
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Best regard
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Downgrading to older firmware
Pretty sure I tried this last time and it didn't work!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Give it another try, those directions are spot on and will work. There may have been a hiccup.
