× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
Game Searching
Breezo
Tutor
Game Searching
I have a moderate NAT type how can I get an open one, also takes pretty long to find games with a vpn and geo filter active What can I do to find game quicker?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 9
Netduma-Fraser
NetDuma Partner
Re: Game Searching
You can follow a guide here for NAT: http://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-o...
Using a VPN adds extra hops and latency, you're also likely connecting to a VPN/forcing a game server far away which will mean longer search times - that's normal and that is why we don't recommend it.
Message 2 of 9
Breezo
Tutor
Re: Game Searching
I am on a vpn, how come after a couple games usually 1-2 I can't find any lobbies and I have to restart my app n refresh n restart my vpn to to find games agai.
Message 3 of 9
Netduma-Fraser
NetDuma Partner
Re: Game Searching
This could be anything, it could be the VPN server is under load or the game is trying not to put you in games where your ping would be so much higher than everyone else
Message 4 of 9
Breezo
Tutor
Re: Game Searching
How come is takes long to find games when I search with friends in my lobby?
Message 5 of 9
Netduma-Liam
NetDuma Partner
Re: Game Searching
Are you trying to connect to very distant servers? If so, it's likely just the fact that the game server is reluctant to put multiple players with high ping into a game. You'll have a much better experience filtering local servers.
Message 6 of 9
Breezo
Tutor
Re: Game Searching
No I only connecting to close servers, so why is it taking so long, what can I do to speed it up?
Message 7 of 9
Netduma-Fraser
NetDuma Partner
Re: Game Searching
Where abouts are you located and where are the servers you're trying to force?
Message 8 of 9
SewardDamian
Re: Game Searching
Vpn only helps the game change to another address, will not make it faster.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2069 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
