× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
IPV6 stops QOS
OverTime247
Guide
IPV6 stops QOS
Downloaded the new firmware
XR500 V2.3.2.104-DumaOS3.0-Beta , turned on ipv6 and it hooked right to it , ran a connectivity and speed test and it looked good , but when i applied qos i got  Error: RPC error 'ERROR_NOENT': Rule not found in chain , tried other rapps and they worked fine , no errors , disabled and rebooted and back to normal. What ever you guys did to fix the bug that hit everybody a few days ago seems to have worked , Thx.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: IPV6 stops QOS
That bug should have been fixed in that firmware and so given the issues with that firmware there is probably no need to report anything at the moment. Wait for the next firmware please and let us know if it is fixed then because that bug specifically should be sorted.
Message 2 of 2
All Replies
Netduma-Fraser
NetDuma Partner
Re: IPV6 stops QOS
Message 2 of 2
Discussion stats
  • 1 reply
  • 2536 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
