- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet drop out everyday on XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
my XR500 router ramdomly drops connectivity to all my devices (both wired and wireless). The WAN signal is still present (LED stays white) while it happens. After 5 minutes router is back online. It has started to drop two times a day, randomly, since 3 days ago. Any ideas?
My router is currently on Firmware Version 2.3.2.114. I had it run on the latest netduma os 3 beta .120 when his started to happen and reverted it back to .114, still the problem occurs.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet drop out everyday on XR500
What modem/gateway is it connected to?
when things are happening to both wired/wireless, its always good to check the modem.
You could hook a computer/pc directly to the modem and use it for a day. If its dropping 2x a day, that'd tell you pretty quick if the modem is stable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is conntected directly to the fiberLan, on the wall, there is only one FiberLa to plugin, where my ethernet cable in plugged in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I need a guideline for that. Any link?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You mean in the LAN section:
Starting IP Adress: 192.168.1.2
Ending IP Adress: 192.168.1.254
Could you clearify it please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I understand about the Starting Ip Adress, giving it to .50 instead of 2, but what about Ending Ip Adress which says .254?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did it as you asked, I hope it will resolve the problem.
@Netduma-Fraser wrote:
Yes change the starting IP to 192.168.1.50, then reserve IP addresses on the same page for your devices - give them IPs ending between .2 and .49
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I willv:)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now the bandwitdh is messed up now, I have allocated 90 % to my ps4, and within call of duty games' option, the bandwidth is set to 1Kbps. It seems that the QoS is confused by the reserved IP adresses.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem is solved when I restarted the router. One more thing, is there a log in my router where I can see if it has had internet drop outs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah man it's back again, 1Kps bandwitdh....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes it does
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here it is, it's from the game, cold war https://imgur.com/a/utBFOXj
- Mark as New
- Bookmark
- Subscribe
- Permalink
That can't be correct if you're still able to play a game though, it must just be mis-reported by CoD. Can you run a speed test on the console? I suspect you'll still be seeing full speeds here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still not sure what modem/gateway you're using
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What fibre ONT is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The download and upload speed on console is pretty good, must be the game that confuses me.
