- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is there a bugfix for this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
[DumaOS] config write 'com.netdumasoftware.qos.settings', Thursday, November 05, 2020 17:10:22
[DumaOS] RPC call 'disabled' exception 'ERROR: Rule not found in chain stack traceback: ^I?: in function '__new__' ^I?: in func,ion '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in function <?:238> ^I(tail call): ? ^I(tail call): ? ^I?: in function '?' ^I?: in function 'reset_interface' ^I?: in function '?' ^I?: in function 'reset' ^I... ^I[C]: in function 'run' ^I?: in function <?:404> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I?: in function <?:263> ^I(tail call): ? ^I?: in function <?:30> ^I[C]: in function 'xpcall' ^I?: in main chunk ^I[C]: ?' Thursday, November 05, 2020 17:10:19
[DumaOS] Long call 'del_rule' exception 'ERROR: Rule not found in chain stack traceback: ^I?: in function '__new__' ^I?: in fun,tion '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in main chunk ^I[C]: in function 'require' ^I?: in main chunk ^I[C]: in function 'require' ^I?: in main chunk ^I?: in function <?:263> ^I(tail call): ? ^I?: in function <?:30> ^I[C]: in function 'xpcall' ^I?: in main chunk ^I[C]: ?' Thursday, November 05, 2020 17:10:19
[DumaOS] RPC call 'set_dpi_settings' exception 'ERROR: Exec 'ip6tables -t mangle -D nd_output_mangle -p udp --sport 53 -m mar, --mark 0x0/0x7fc000 -j NFQUEUE --queue-num 1 ' failed with 1 stack traceback: ^I?: in function '__new__' ^I?: in function '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in function <?:238> ^I(tail call): ? ^I(tail call): ? ^I?: in function '?' ^I?: in function <?:510> ^I?: in function <?:382> ^I[C]: in function 'xpcall' ^I... ^I[C]: in function 'run' ^I?: in function <?:404> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I?: in function <?:263> ^I(tail call): ? ^I?: in function <?:30> ^I[C]: in function 'xpcall' ^I?: in main chunk ^I[C]: ?' Thursday, November 05, 2020 17:10:19
[DumaOS] Long call 'del_rule' exception 'ERROR: Exec 'ip6tables -t mangle -D nd_output_mangle -p udp --sport 53 -m mark --mar, 0x0/0x7fc000 -j NFQUEUE --queue-num 1 ' failed with 1 stack traceback: ^I?: in function '__new__' ^I?: in function '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in function 'safe_execute' ^I?: in function <?:1104> ^I?: in function '?' ^I?: in function '?' ^I?: in function <?:200> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I... ^I[C]: in function 'run' ^I?: in function <?:404> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I?: in function <?:263> ^I(tail call): ? ^I?: in function <?:30> ^I[C]: in function 'xpcall' ^I?: in main chunk ^I[C]: ?' Thursday, November 05, 2020 17:10:19
[DumaOS] config write 'com.netdumasoftware.qos.settings', Thursday, November 05, 2020 17:10:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is there a bugfix for this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The QoS is completely broken. I had to do some leg work to disable QoS since the disable button was broken too. Wasn't fun. Hoping the next release will have this fixed. I had to go through this process as it caused IPTV to result in black picture on changing the channel. Sometimes you have to wait 5 minutes for picture to come back. Sometimes it doesn't com back. The system I'm on is similar and same equipment was Xfinity system. Using Rogers IgniteTV here.
The other bug I'm noticing is that when WAN is configured for DHCP and the DHCP lease is renewed, it'll shutdown the LAN ports briefly. I think I reported this previously on the other forums. It was a significant problem when my ISP had a lease time at 1 hour. Every 30 mins I would get briefly disconnected as the LAN ports restarted. I got the ISP to increase the lease time to 2 days which minimizes the impact.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, Rogers provides the IPTV service via their Xi6 boxes. It's wirelessly connected to the XR via WiFi. Part in troubleshooting the DHCP Lease issues I had with Rogers, they replaced the Arris XB6 cable modem with Technicolor XB6.
Just googling the device, here's what the Xi6 looks like https://communityforums.rogers.com/t5/image/serverpage/image-id/7659i5AF47305E8270403?v=1.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There isn't a box to connect to. I would either have to give up using the XR500 as a router and use the XB6 cable modem as the router instead. The connectivity is all WiFi based.
Turning off QoS fixed the black picture issue. This wasn't a problem with the GA release firmware, only the beta firmware is producing black picture.
- Mark as New
- Bookmark
- Subscribe
- Permalink
