- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
All of the sudden my router doesn't connect to Internet at all and I double checked the connection using an old Tp-link router which worked fine...So I had no choice other than to Hard reset the router and after the reset none of the R-apps load, it keeps spinning for quite some time and comes up with error "This Rapp is not loaded yet,please try again in a minute"... I once had same issue with previous beta build however, a computer restart fixed that issue but no luck with this build.... I even flashed the latest stable build in which all R-apps worked fine and then flashed the beta build (DumaOS 3.0.139) and performed a reset through Serttings but issue still persist... Are there any fix for this issue? It is really frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
URGENT!
Same here. All of a sudden, I thought my internet was down. Whichever device I disconnected from my router like my Note 10 phone where I turned off the WiFi and turned back on, will not connect to the router anymore. My PC which is connected via wired can't access the internet but can still access the router.
I tried talking to Alexa. I can still get weather information and even control my Home Automation devices. So whichever device which are not disconnected via WiFi from my router will still have internet access.
I then restarted my modem and router. Still no luck. I downgraded to the previous beta firmware. Still no luck. Btw, at this point, all devices can't connect via WiFi and I made sure to turn off and on the WiFi using the physical button on the router.
The only way to get all devices to connect to the router via WiFi is when the router is starting up. But the devices will not be able to get internet access.
At the same time, when the router has just finished starting up, my wired PC can access certain webpages just fine but a few seconds later, less than 10 seconds, I'll get disconnected from the internet.
I then proceeded to directly connect my wired PC to the modem. And voila. Problem free. Everything loads fast without any issues. So it is definitely the router problem since if it wasn't, it should still allow the devices to connect to its WiFi network. In this case, it doesn't let any device to connect after that initial few seconds after startup. Could it be a DHCP server bug?
Anyway, a nightmare for me happened. I was unable to connect to the router page after I connected the PC back to the router and connected the modem ethernet cable back to the router.
I tried restarting the PC. Flush DNS. Using another internet browser. No luck. Routerlogin.net also doesn't work. I also power cycled to no luck.
The only way was to power down the router for a few minutes instead of the typical 15 second shut down. Only then, I was able to access the router page. I still couldn't access the internet. I upgraded the firmware back to the latest beta and again, was able to connect to the internet for the few initial second. This is how I am typing here right now. Weirdly enough, this netgear page that is opened, I can still access its other threads. But I can't access any other internet page that I didn't open before it disconnected me from the internet. I tried letting the ISP choose the DNS server. The problem persists.
And now, with someone else mentioning the same problem as me just a few minutes apart, goes to show that it is indeed this router with either this beta firmware causing this issue. Thus why I am writing this.
As of now, I didn't attempt to downgrade to the official firmware or do a Factory Reset in case in breaks more stuff. Since I tried doing that once before and using my backup settings didn't restore my fixed IP address reservation page. What a headache that was to type in. So no thanks on doing a factory reset.
How can I get this issue fixed asap?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Exact same thing !
In the log I have process '/usr/bin/dpiclass' died restart:true message looping !
Does it means there is an idem update mecanism that messed up something ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
hello two days ago qos, it turned off by itself, today again, I turned it on and the problems started, the internet disappeared, I can't connect in any way, only 10.0.0.1 worked, but only for a while, reinstallation does not work, I mean it works until when a message pops up conflict ip 10.0.0.1, then the router gets stupid, nothing can be done, the lights show the internet, but there is no suggestion anywhere,
nothing works
http://routerlogin.net/adv_index.htm
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I think you might have just found a temporary fix to the internet problem. (But no fix for WiFi yet)
I went to the QOS tab --> Clicked on the 'Options' beside Congestion Control --> Ticked 'Disable QoS'. Voila. My internet is working fine on my PC.
Hmm.. It seems to only help my wired PC. I still can't get my phone to connect to the router's WiFi. The error I get on my phone is, 'Couldn't get IP address'. Which lead me to believe that the DHCP server is bugged too.
But since all of us are facing this issue at the same time, it could even be a time bug. I am going to try to manually alter the time to a few days ago to see if it fixes this issue. If it does, I will report back here.
Edit: Yeah.. Altering the timezone didn't help. There is no way to manually alter the time. So no luck with changing the time to see if this is a timed bug.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So, here is what I did.... I restarted the routered via settings to fix the R-app loading issue and suprisingly it got fixed but guess what? the initial problem occurred again which is I no longer can access Internet both Wired and Wifi devices (which was the initial issue)...I rebooted the router multiple times and sometime it connects to Internet for few seconds (may be linke 3 -4 seconds) but then it stops working...Now I see one more person is having similar issue, Thanks to @LiLAsN for the suggestion on Disabling QoS completely which now allows me to connect to internet on my main PC (Wired connection) however I'm still not able to connect any Wifi devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
TFTP: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
.56: https://kb.netgear.com/000061157/XR500-Firmware-Version-2-3-2-56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I gave up as of now. And since my wired PC is able to connect to the internet, I went to download the old official firmware (XR500-V2.3.2.56). Not these 2 beta firmwares. I've uploaded the old firmware to the XR500. I can now connect my phone to the router's WiFi network too. So all the issues seem to have been solved by using the official XR500 firmware for now.
So sorry to the DumaOS team. This bug is too game breaking. I still have other family members and I depend on a lot of Home Automation. So to not be able to get WiFi up with the current Beta firmwares, I have no choice but to go back. Will look forward to the next firmware iteration that will fix this bug as to allow me to play around with the overall better experience that I was having with the latest Beta firmware except for the bug that I faced today. It is just too disruptive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@locosano you can't access the router page using routerlogin.net however u can access it with your default gateway IP address...
@Netduma-Fraser Sadly it seems, going back to the stable built is the only option but do you have any idea why this issue occurred out of nowhere? I could understand that if this issue occurred when I was messing around with some settings which might have broke something but I didn't. This Beta build was working fine (at least the basic features) all these while and this suddenly appears outta nowhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I spent 3 hours this morning trying to figure out why my internet was completely down and had to eventually rollback my firmware to the official .56 release to get things back up and running. There must of been some cloud update or something that came through last night that completely messed everything up. Reminds me of the "DumaOS Not Loaded" situation last year. I understand running beta software will have bugs but this is completely unacceptable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Not your fault Fraser, you are doing a fantastic job as a forum support guy and kudos to that...It's just the devs either from NetDuma or Netgear screwing things up. Anyway it's not a great deal to roll back to stable built cos most of the main features which suppose to work in 3.0 were either buggy or completely not working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Betreff: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
also i have the smae problem with my xr500
shoild i go back to 3.0.92
i have now 3.0.139
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
thank you and the team for the work .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello,
I too have had the same problem today. I had to turn the power off at my house to do some electrical work, and when i turned it back on, none of my devices could connect to the internet. I kept getting the message "self assigned IP address" on my computer and couldn't access the internet. I restarted my modem and router about 10 times before I had to hold the reset button and restart the router. The router however did still have DumaOs 3.0 still installed, I thought that would factory reset it to the default software but it didn't. Anyhow, now it's back up and running.
Thanks,
Bruthless1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Netduma-Fraser For me it happened that qos started to turn off by itself, after an expensive start the router just died, now I miraculously returned to 56 everything works even the devices shows online, I will add a photo when trying to install 56
I had no such weird sides before
