- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
Just to clarify, should it be 'on' or 'off'?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should be unticked by default which means its ‘enabled’, if you tick it and apply it will make the SIP ALG be ‘disabled’ which is what I suggested to do.
If you still suffer disconnects then you can either re-enable or leave disabled.
Cheers,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
100% this. I didn't factory reset after installing the update. I suspect it may be an item that has changed in the beta since I can't find it to unpin anywhere else. Thankfully, it's not causing any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: High Load Average on Router
So my CPU spiked again on the router. I was able to get in to it this morning to grab some screen shots of the CPU usage. All devices went offline about midnight EST. The time on the router was also incorrect. I had to reapply the NTP settings to update the router to the correct time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not even 24 hours and you hit an issue, not great.
Did you happen to look at the logs to see if there was any unusual logs observed while this issue was happening? More than likely that would of given you clues as to what is causing the problems.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I honestly forgot to take a look at the logs, so I don't know what caused this CPU spike. I just know it has been happening with the latest beta update. I have done numerous factory resets on the router. I even went back to the latest stable DumaOS 2.0 version, did a factory reset, let it run for a day, then updated to 2.3.2.104 and did another factory reset. To reduce the load on the router I rebuilt my Raspberry PI and now that is running DNS, DHCP, & PiHole.
Checking my logs now I am seeing a lot of ARP issues:
[admin login] from source 192.168.1.3, Thursday, September 17, 2020 08:01:43
[DumaOS] Error parsing line in ARP table: 'fe80::5815:5dff:fe67:5d71 dev br0 lladdr 5a:15:5d:67:5d:71 STALE', Thursday, Septembe
[admin login] from source 192.168.1.3, Thursday, September 17, 2020 07:55:21
[DumaOS] Error parsing line in ARP table: 'fe80::41a5:62ee:1ab3:cbd6 dev br0 lladdr e6:8f:f0:4f:a4:7c STALE', Thursday, Septembe
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Thursday, September 17, 2020 07:53:06
I will have to setup an email server today so I can automatically send myself copies of the logs daily to monitor these issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah the logs might of been useful to see what was going on.
Regarding the ARP issues, it relates to IPv6, I have the same happening on mine, I don't use IPv6 though so it's not causing me problems.
I think everyone is receiving those errors on the latest beta firmware.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still have disconnects. It's bizzare I have "0" issues when connected to the guest network. The wifi is clearer than cell service then....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LevelUpLiam24 understood thanks for that. Would definitely recommend doing a reset after installing beta firmware generally.
@mreich1978 thanks for the information, I’ve made a topic here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/Devices-disconnected-100-CPU-Used/m... If you can please try and get the logs if it happens again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port 4 is physically disconnected which is also shown in the device manager
gui, however the physical led indicator lights are wrong, it shows Port 1 disconnected while Port 4 led light is on
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't be sorry, better than nothing! Thanks for the effort!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
com.netdumasoftware.trafficcontroller - Crashed
Not sure what happened but traffic controller Rapp seemed to crash, all I had been doing was browsing 'Network Monitor', 'System Information' & 'Device Manager'
[DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pendin, Thursday, September 17, 2020 20:2
[DumaOS] App 'com.netdumasoftware.trafficcontroller' initialised & starting., Thursday, September 17, 2020 20:26:21
[DumaOS] subscribe to 'com.netdumasoftware.devicemanager' from 'com.netdumasoftware.trafficcontroller, Thursday, September 17, 2
[DumaOS] Restarting 'com.netdumasoftware.trafficcontroller' for 0 time, Thursday, September 17, 2020 20:26:21
[DumaOS] ---- rapp end com.netdumasoftware.trafficcontroller, #cstack 0 #res 0, flushing, Thursday, September 17, 2020 20:26:21
[DumaOS] App 'com.netdumasoftware.trafficcontroller' cleanup finished, Thursday, September 17, 2020 20:26:21
[DumaOS] Timer callback failed with 'Unterminated JSON encoded object found at position in [], Thursday, September 17, 2020 20:2
Free RAM hanging in there at between 12 - 14%
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: com.netdumasoftware.trafficcontroller - Crashed
@TheFuzzyOne87 did you get an error message on the Traffic Controller page? Could you use the feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wasn't even on the traffic controller page which is the odd thing.
Error seen now when I go onto the traffic controller page now.
[DumaOS] RPC call 'get_rules' exception 'Unterminated JSON encoded object found at position in [] -> stack traceback: ^I?: in f,
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser They conflict, Device Manager Shows Correctly with Port 4 Down where your suggestion shows below and the led matches the below which is settings > monitoring > Stats
Port | Status | TxPkts | RxPkts | Collisions | Tx B/s | Rx B/s | Up Time |
WAN | 1000M/Full | 11443914 | 33477579 | 0 | 33990 | 75152 | 03:33:25 |
LAN 1 | Link Down | 19095782 | 8792898 | 0 | 75152 | 23679 | 00:00:00 |
LAN 2 | 1000M/Full | 15:51:47 | |||||
LAN 3 | 1000M/Full | 15:51:47 | |||||
LAN 4 | 100M/Full | 15:51:47 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-FraserYes I have already factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Contstanly Prompted for Credentials
This morning when firing up the GUI, I just kept being prompted for the password, it would load a bit at a time but would still propmp me for credentials every few seconds.
Logs showed the QoS Rapp had crashed and restarted, traffic controller etc looks like it had been crashing and restarting through the night.
Due to the other issues mentioned previously and your suggestion to factory reset, I have done that now.
Cheers,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Contstanly Prompted for Credentials
@Bishop555 thank you, @iceway_zhang please look at why the LEDs and stats page are not reporting the port link properly.
@Tripper_ thank you, I’ve reopened the internal ticket and have passed it back to the developer.
@TheFuzzyOne87 okay that is really strange, please let us know if it happens again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Goodput error when selecting or deselcting. RPC error 'ERROR_NOENT': Rule not found in chain
- Mark as New
- Bookmark
- Subscribe
- Permalink
