- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Guitarslynger79 been through the manuels and every setting on this modem/router and it does not have the bridge mode. If you are able to assist me and prove me wrong i would be open to it. Because i am unfortunately unable to locate it after many times of trying to
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-FraserI managed to put my Mac address on my XR 500 into DMZ on my modem/ Router and retarted both my XR 500 and my modem/router right after and went back to ping heatmap to see if anything has changed and unfotuantly the issue is still there. It does not display any servers at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Guitarslynger79 Thank you a lot for the help and support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://exewiki.exetel.com.au/index.php?title=ZTE_H268A_-_Bridge_Mode
Follow the steps as per the wiki to get it to bridge mode, run ethernet cable from one of the numbered ports on the ZTE to the yellow internet port on the XR500. From there, log into the XR and navigate to the setup tab, internet setup, and if you have a login to your ISP, do so there if it's a pppoe. If there's no login, just leave it default. Or consult the XR manual on login credentials just in case I missed anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Guitarslynger79just looked the link you provided me and by following it I come across first the
WAN option not even being avaiable under internet and looking thought thr setting for a WAN option it doesnt seems to appear. I believe the modem has removed this feature in later firmware updates and does no longer support Brigde mode.
Will supply a screenshort below.
But many thanks again for the help and the effort.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraserunfortunately the steps is no longer efficient since it seems the feature has been removed in a later firmware update for the modem.
The WAN option is not even there anymore under internet or any other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just provide an overview board with information like: IP Version, NAT, IP Address, DNS and so on but the board only shows the data and not not be manipulated or changed in any way. Only showing the information @Guitarslynger79
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Guitarslynger79 Yes unfortunately when you click on the admin. You are forced to login again and then it will provide you with the exact same page as prior. With no updated features not listed before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Guitarslynger79 I am located in London region and I did manged to set up a DMZ to the mac address for my xr50 and rebooted both the modem and the rx500 but it did not fix the issue with the ping heatmap.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser " flush the cloud " option i only have in the Geo filter section. In the Ping Heatmap i have something called " Force update cloud " When you click on that button it will pop up with a loading icon in the middle of the screen with a red background, After is done it will go back to displaying no servers as it previously did
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Anton774 wrote:@Netduma-Fraser " flush the cloud " option i only have in the Geo filter section. In the Ping Heatmap i have something called " Force update cloud " When you click on that button it will pop up with a loading icon in the middle of the screen with a red background, After is done it will go back to displaying no servers as it previously did
- Mark as New
- Bookmark
- Subscribe
- Permalink
No they do not @Netduma-Fraser
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone. Is there any word on the ability to enable telnet? In version 2 we could go to debug.htm and enable it, but this option within this page has gone. Is there another way to enable it, or will it not be returning?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Retired_Member
It was removed in the latest unfortunately, I would like it re-introduced too, if you was to downgrade one release it is available still.
Maybe they are planning on introducing it as an 'Rapp'? Doubt it though lol.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @TheFuzzyOne87,
That is a little dissapointing - as sometimes it is great to have Telnet on there (be even better to have SSH!!), and via a webpage/Rapp would be best. I did find a solution that might help - I used NTE successfully to enable telnet. I hope this helps!
http://www.antinode.info/nte/index.html
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member
Oooo! Thank you so much, I may give it a try
Don't think Netduma or Netgear will be pleased about it though lol
Cheers,
