×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
Rwongega
Re: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
v2.3.2.120
Message 626 of 635
Netduma-Fraser
NetDuma Partner
What phone model are you using the app on?
Message 627 of 635
Rwongega
Tried it on 2 phones I have (work, personal).
iPhone 12 Pro Max  on iOS 14.7 Public Beta 4.
iPhone 12 Pro Max on iOS 14.6
Message 628 of 635
Netduma-Fraser
NetDuma Partner
Can you try uninstalling and then re-installing the app please and see whether it works then? Are you definitely connected to the XR WiFi?
Message 629 of 635
Rwongega
Tried uninstalling and reinstalling both Duma and Nighthawk apps. Still the same problem. And yes, I am connected directly to the XR.
Message 630 of 635
Netduma-Fraser
NetDuma Partner
Could you disable your mobile data so its only connected via wifi and see if it works then?
Message 631 of 635
Rwongega
No change.
Message 632 of 635
Netduma-Fraser
NetDuma Partner
Downgrade to a pre-3.0 firmware version, then re-upgrade, factory reset and try again please
Message 633 of 635
maniac00
QoS App when opened through PC seems to have problems
1. Always I see the below error when QoS is opened. 'Device not found'
2. Traffic prioritisation widget is not loading. It keeps spinning.
Message 634 of 635
Netduma-Fraser
NetDuma Partner
@maniac00 we are aware of the first, downgrading, resetting, then upgrading resolves it at the moment. Give the router a reboot from the interface then wait 2 minutes before accessing should make it load
Message 635 of 635
Top Contributors
Announcements
Orbi WiFi 6E
