Reply
NetDuma Partner
Re: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
@defiled669 what do you mean by applying high priority to the console? What setting precisely have you done to do that?
Message 101 of 600
Apprentice
in qos at the bottom left you can add your console to hig traffic prioitization.if you do this it cancels your qos
Message 102 of 600
NetDuma Partner
What do you mean it cancels QoS? Traffic Prioritization does supersede Congestion Control to get your gaming packets at the front of the queue, as they don't take up a lot of bandwidth this doesn't usually cause any issues. How did you add it, with the console service?
Message 103 of 600
I am using a gaming desktop on Google Chrome. The ping heatmap was working just before I did the firmaware update. Yes I am connected to the internet. lol
https://imgur.com/RKYND3o
https://imgur.com/ldDVamG
https://imgur.com/ZvSAzug
Message 104 of 600
I just tried it on Edge and it didn't work either.
Message 105 of 600
Apprentice
does anyone know what these entries are NOP
Using disabled(NOP) QoS subclass, Saturday, August 29, 2020 14:01:28
[DumaOS] applying qos for zone lan, Saturday, August 29, 2020 14:00:29
[DumaOS] Using disabled(NOP) QoS subclass, Saturday, August 29, 2020 14:00:29
[DumaOS] applying qos for zone wan, Saturday, August 29, 2020 14:00:28
[DumaOS] Using disabled(NOP) QoS subclass, Saturday, August 29, 2020 14:00:28
[DumaOS] applying qos for zone lan, Saturday, August 29, 2020 14:00:23
[DumaOS] Using disabled(NOP) QoS subclass, Saturday, August 29, 2020 14:00:23
[DumaOS] applying qos for zone wan, Saturday, August 29, 2020 14:00:22
[DumaOS] Using disabled(NOP) QoS subclass, Saturday, August 29, 2020 14:00:22
Message 106 of 600
NetDuma Partner
@alongcory was that when you tried to ping a game or when you tried to flush the cloud yourself? The only time I've seen that is when the cable from the ISP hub was plugged into the XR LAN port instead of the WAN port - I assume you have it connected the correct way?
@Raf1212 you don't need to worry about any log entries, they are verbose and so sometimes will appear as though there is an issue even if there isn't.
Message 107 of 600
@Netduma-Fraser : My "Auto-Ping" feature is working fine. When I boot up a game it is correctly showing the ping to the server/peers. The only thing that isn't working is the acutal heat map. Please see video: https://streamable.com/7keo7f
Yes the it is in the correct ports. ISP Hub yellow port --> XR500 Yellow port.
Message 108 of 600
NetDuma Partner
@alongcory could you unpin it from the dashboard please and see if it loads correctly then?
Message 109 of 600
i always get when i change  something
RPC error ERROR-NOENT
rule not find in chain
Message 110 of 600
when i change something in QOS  a always get
Message 111 of 600
NetDuma Partner
Message 112 of 600
whenver i change any sitttttttting ??????
https://imgur.com/vSzNW6I
Message 113 of 600
on option on QOS when i switch from Applications to
Devices then i refresh the page and sing in again
Message 114 of 600
Message 115 of 600
https://imgur.com/HbzgmrX
cant delet any rule ??? in qos  traffic prioritazion
Message 116 of 600
Apprentice
It all stems from the device manager being broken. Use the work around posted, and set static ips for devices that need qos and traffic prio. Im hoping that there's a fix very shortly for this. Its rather frustrating as if I dont have qos I hit my network providers traffic policer and all hell breaks loose.
Message 117 of 600
NetDuma Partner
@Aboodi12345 if you have any more issues regarding that error please post it in the topic above. Did you save the distribution for Bandwidth Allocation?
Message 118 of 600
yes i save it .. but when i refresh the page the setup back by it slef
Message 119 of 600
NetDuma Partner
It resets the actual values completely? We'll have a new firmware very soon so please try that when it is available and see if the same occurs.
Message 120 of 600
Thanks for allowing me the privilege of testing duma os 3.0. The only thing I have ran into yet is the ping heat map. It’s saying this Rapp is not loaded yet, please try again in a minute
Model: XR500|Nighthawk Pro Gaming Router
Message 121 of 600
NetDuma Partner
@ConcreteSlayr if you reboot does it load correctly? There will be a new firmware soon to try so hopefully will work fine then.
Message 122 of 600
my connection has been bad since march and i cant do it anymore with this lag ive tried replacing equipment and still lag as bad https://www.youtube.com/watch?v=szI8AY9nvi0
Message 123 of 600
Message 124 of 600
Tutor
Internet slowed down to a crawl, every web page failed to load on all devices. Tweetdeck occasionaly loaded tweets, but no images came through. Couldn't access DumaOS UI over LAN or Wi-Fi, and was forced to push the power button on the back of the router to reboot.
Message 125 of 600
Announcements
