- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue reporting thread - POST NEW ISSUES HERE (V 2.63 running DumaOS 3.0.139)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Once I upgraded I factory reset (just to be on the safe side) and re-applied all my custom settings etc.
Only issue I see at the minute is something about ARP issues, feeling a bit too lazy to be bothered to look at which devices its complaining about though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the beta now includes xr450 can I download the xr500 firmware and apply and use it to update my 450 or are they releasing the 450 firmware soon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When disabling Goodput, I recive the following error:
RPC error 'ERROR_NOENT': Rule not found in chain
I'm also only getting about half my bandwidth in the Connection Test. Connected via Ethernet. Speedtest result is Ping 9 ms / Down 938.61 Mbps / Up 634.43 Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just signed on today for the beta. Am I able to download the latest beta version on top of my existing version?
XR500 V2.3.2.56
Thanks,
Brandon
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can, I've just updated from V2.3.2.56 without any issues 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
what happened to that store addon to the top right that was there its not there anymore on the netgear nighthawk router
- Mark as New
- Bookmark
- Subscribe
- Permalink
V2.3.2.104-DumaOS3.0-Beta
- PPPoE UPnP bug is still present (ports open but the list is empty)
- Connection Benchmark uses full speed regardless of QoS sliders or Always/Auto-Enable/Never
- Connection Benchmark does not work with upload under load (I could set my QoS slider to 1% and it will still get bufferbloat)
- Two of my devices started showing offline after the latest update
I was actually excited to test the new Auto-setup under QOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd like to leave this post for the general discussion thread. But I don't know how to delete this post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tested beta
XR500-V2.3.2.104 and it works quite stably for now ,
the other problem is (old problem with old firmware) QoS and IPTV app on my tv, IPTV App on my Samsung doesn't work until QoS is turned off.
When QoS is turned on, all devices where I have the application with iptv installed do not work, and when QoS is turned off, all devices on which IPTV is watched work properly.
I also have two exra routers next to the netgear Xr500, asus AX_88U and Linksys WRT32X where is QoS turned on, but IPTV works Perfect on both - TV and other devices.
i don't understand how this can be a big problem and that it can't be solved for so long.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For those having some issues on the latest firmware did you do a factory reset after upgrading?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Issues I have noticed so far:
Process that keeps failing:
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound,
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending,
[DumaOS] process '/usr/bin/dpiclass' died restart:true,
UPNP:
Same issue as usual where port does not get cleared up. I see the page that has been created for this issue has now been removed.
The NETGEAR Nighthawk App (on iPhone):
When trying to do a Speedtest via it, the upload completes but on download it fails with the error;
Connection Failed
If the problem persists try rebooting your router.
(I have tried a reboot no difference).
On the debug page the telnet option has been removed now, imagine this is intentional but now quite annoying to track issues I was looking at, aka there is a constant arp issue being reported, not in the log to paste at the moment as a bunch of things has been updated from the 'cloud' by the looks of it, will paste that error when I see it again too.
Feels a lot better overall though! My gratitude to the team.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Process I performed after the other nights mass issue on the previous Beta firmware.
- Gained access to router via wire.
- Took a backup of config.
- Factory Reset, issue still persisted.
- Uploaded the Official Stable Release Firmware.
- Restored config via the backup file (Yes I know I shouldn't of but it was late).
- Few errors was thrown but nothing that stopped the device working on the Official Release.
- Alex announced new firmware was released.
- Downloaded new firmware and uploaded / upgraded router via wireless.
- Once new firmware installed I factory reset.
- Setup everything from scratch (not by backup).
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
ARP issue
Here is the error log for the ARP issue:
[DumaOS] Error parsing line in ARP table: 'fe80::18e8:2f8e:3d6e:a6c0 dev br0 lladdr a4:d9:31:cc:d2:3e STALE'
- Mark as New
- Bookmark
- Subscribe
- Permalink
@iceway_zhang could you look into the UPnP and App issues please?
Are you getting issues with IPv6 also?
- Mark as New
- Bookmark
- Subscribe
- Permalink
not that I have noticed.
I have turned off the default traffic prioritization and selected just my xbox and selected the 'Games Console' as the service.
Due to being with Virgin Media IPv6 is pretty much useless so I don't have this enabled.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For UPnP issue, as Router do not manage port mapping add/delete action in itself firewall manager, just upnp server accept SOAP requirement from Client to add or delete port mapping rule, thus, client should remove it via send a SOAP packet to delete specify port mapping rule.
For App issue, do you mean below issue?
The NETGEAR Nighthawk App (on iPhone): When trying to do a Speedtest via it, the upload completes but on download it fails with the error; Connection Failed
