- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
New Firmware v2.3.2.108 (XR450)
Hi all,
We have another firmware for you to test. Thank you for your patience so far. I don't have a change log available at the moment but I assume you would like to try it now vs waiting any longer. Once I have the change log I will update this post with it.
I would highly recommend you do a factory reset after upgrading for the freshest installation.
Firmware:
https://www.dropbox.com/s/32767c9x96pilkj/XR450-V2.3.2.108.zip?dl=0
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: New Firmware v2.3.2.108 (XR450)
Thank you Sir. Will get it loaded and right on to testing.
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, got v108 loaded over v106.
First item that stuck out at me was how long it took for any indication of the factory reset to be seen on the front panel LEDs. With a wired PC and MS Edge browser connected, I use the ERASE function under Advanced/Admin/Backup settings menu. Selected the ERASE button and the browser said it was in progress. I watched the front LED panel and seemed to take 30-45seconds before the LEDs changed and went out. I'm used to seeing something with in about 10-15seconds usually.
2nd item is that I noticed is that I can't access the routers web page using 192.168.1.1, I have to use routerlogin.com in Edge. I tried both HTTP and HTTPS and Edge says it can't access the page with 192.168.1.1. However If I use Opera GX browser, it logs into 192.168.1.1 just fine. Something Edge isn't handling correctly with newer FW versions? I noticed this on a NG R7960P as well recently.
More testing to come.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ok, problem cleared by browser cache clear. Edge works at 192.168.1.1. Odd that the broswer gets stuck until the cache is cleared.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is ipv6 broken? i cant get it to work
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
must be a bug i dasabled qos and ipv6 works
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Did you factory reset the XR router after applying v108 and setup from scratch?
@dewayne221 wrote:must be a bug i dasabled qos and ipv6 works
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@FURRYe38 wrote:Did you factory reset the XR router after applying v108 and setup from scratch?
yes
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Can you determine if this issue can be narrowed down to just QoS or just IPv6? Or is it both?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Netduma-Liam wrote:Can you determine if this issue can be narrowed down to just QoS or just IPv6? Or is it both?
Im not sure with qos enabled it looked like it was getting a ipv6 wan address but it wasnt working for some reason
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Netduma-Fraser wrote:
@dewayne221we're aware of issues with these both enabled and are looking into it.
Oh ok
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
is there a newer update to the XR450 then V2.3.2.108 cuz theres alot of bugs still
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So is the REBOOT option not supported while the XR450 is in AP Mode with v108 FW loaded?
Happens in Safari an Opera GX on Mac. I haven't check Windows. I presume it maybe the same.
Would be a good feature to enabled if thats possible for AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok, Understand now. I forgot to look under settings.
However, another interesting item I found on this v108 FW. I notice that the reported 2.4Ghz connection rate being seen is 800Mpbs?
I thought 2.4Ghz was 600Mpbs for the Xr450?
• AC2400 (600Mbps@2.4GHz-64QAM support+1733Mbps@5GHz 11ac)†
I need to get my wifi bridge out and check this to see what the actual rate is...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ok so I tested this on my ASUS GT-AX11000 in wireless bridge mode. It's only seeing 600Mpbs on 2.4Ghz:
Getting 1733Mpbs on 5Ghz:
Actual speed testing with the XR450 connected to a NetDuma R2 router and the GT-11000 doesn't seem to result in good speeds on a 1Gb ISP service.
I had QOS enabled on the R2 for this test:
I disabled QOS on the R2 then tested again:
Both test bell curves started out going fast then tapered off to a slower speed at each test.
ASUS device was placed about 8 feet from the XR450.
I have a EAX80 and R7800 that supports 1733Mbps that I can try tomorrow for comparison testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Sounds good. Probably just a UI change for the connection rate.
