- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.108 (XR450)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.108 (XR450)
Here is an EAX80 conneted to the XR450:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speed test results with EAX80 and XR450:
Bell curve seems better with the EA80 vs ASUS. Saw better speed results with EAX80.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got a problem with the wifi settings, for 2.4Ghz. Stuck at 40Mhz, now and used to be able to change that to 20Mhz. Has that ability been taken out or is it that I can't find it, to change it to 20Mhz? The 5Ghz channels are at 80Mhz, as they were, before. Also, 2.4Ghz won't change to any different channel (1 through 11) and is showing it is on 4(6) at 40Mhz. Manual attempts to change the channel to a much less populated one, fail.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is from an app on my phone, since there isn't any way to show what I'm talking about, from within the router firmware section for Wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Screen shot of Wireless section
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Drops the 2.4Ghz speed to ~285mbps, from 600 and it, briefly, went to 20Mhz, on channel 4, then back to 40Mhz and on channel 6, again.
The 2.4Ghz bands are quite crowded, where I live and probably the same holds true, everywhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just changed it to Auto channel select. Went to channel 8 at 20Mhz, 600mbps. Think I'll leave it as is and monitor it, periodically. Lots of devices operating on 2.4Ghz, in my apartment and I've been getting complaints about the lag, which is why I've been trying to figure things out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF your in a wifi congested area, you might want to turn down the power output of the XR 2.4Ghz radios from 100% to 50%. Helps reduce some interferences with the XRs wfif and other wifi signals.
@Old_Soldier wrote:Drops the 2.4Ghz speed to ~285mbps, from 600 and it, briefly, went to 20Mhz, on channel 4, then back to 40Mhz and on channel 6, again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the XR450, how close is it before becoming final? Is there another planned beta version or 3.0 going to be the next update? @Netduma-Fraser
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have the XR450 and I have encountered an issue with the beta firmware.
I have attached a video to show the issue, please check it out as I haven't found a solution so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I did what you asked and it lasted longer when I did that, but eventually it stopped working like in the video.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alright, I hope you guys fix it in the next update. Speaking about the next update, any idea when will that be? Even as an ETA?
@Netduma-Fraser
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alright, thank you for info. I hope it's soon then!
Have a good day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just looking at my XR450 with v108 loaded, Ping Heat Map is loading for me:
I'll keep an eye on it to see if this changes over time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Just looking at my XR450 with v108 loaded, Ping Heat Map is loading for me:
Yeah, that's odd. For me it stops working after a while. The page stops loading for me and I don't know why.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser wrote:
As above, how long does it stop loading for you? In System Information in the Rapp panel options if you change the number of retries from 3 to 5 does that keep it loading for longer?
On the Last test after changing it from 3 to 5 seconds for retries, it took 3 days for it to stop working after the last reboot.
