- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware v2.3.2.108 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware v2.3.2.108 (XR500)
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I turn on 5ghz then I get disconnects during the day from devices randomly and authentication errors. Smart connect makes it worse.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Delx use a WiFi analyzer for 5GHz to find the least congested channel and select that. How far away are the devices that are using 5GHz from the router? How many walls are between them and the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had another series of random crashes to reboot. I had all the debug captures running to a usb stick. What do you guys need me to send in order to have this looked at?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@drcheesenipz wrote:Had another series of random crashes to reboot. I had all the debug captures running to a usb stick. What do you guys need me to send in order to have this looked at?
Another thing worth noting. I just wanted to see what was going on with the system logs on the router, and the CPU load indicator has CPU0 pegged at 100%, and CPU1 goes up and down as usual. Then the whole interface locked up, and I can't get into back into the router config screen: "This site can't be reached, 192.168.1.1 refused to connect." And shortly there after, it crashed to reboot. Saved another round of lan/wan captures, and saved another debug log.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Hartsgrove they should show back online after TFTP & reset when they're actually online, there is an issue where they go offline quickly if there is no traffic but that's different to what you are seeing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
k, I sent him a PM with the debug logs with an explaination.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know a lot of you are still experiencing drop outs etc. I'm not sure if this will help or make any difference but it might be worth trying.
When I upgraded from beta to beta the old bugs carried over like frequent drop outs.
So I flashed to factory then to latest stable then factory reset again then upgraded to beta and it solved all my issues. Running as stable as last stable build but with all beta quirks and additional fixes.
I know your all flashing to the beta but might be worth doing the double or triple I mentioned above.
@Netduma-Fraser Might be worth stickying another thread on home page thuroughly explaining how to do it and why. Also did you pass along the message to add port 6112 to guild wars in os classified games by default?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just tried to do the update and it says the disc image file is corrupted, what do I do from here?
- Mark as New
- Bookmark
- Subscribe
- Permalink
googledrive more easy
https://drive.google.com/file/d/1iG7Z4G3MJqLyASga5BDiQgSD5O2S2CoT/view?usp=sharing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Delete the file you downloaded and download it again. Then try to update your firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good suggestion above, let us know the results!
